[GRASS-QA] GRASS QA: markus | ./grass6/db/drivers/sqlite/execute.c |no clones | 0 monsters | 0 warnings
Sat Nov 24 07:58:55 EST 2007
Hello markus,
ANALYSIS
db/drivers/sqlite/execute.c functions
db__driver_execute_immediate (Begins at: 31 Ends at: 87)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      17 |       |      OK |
LOC:          |      57 |       |      OK |
metrics are OK
db__driver_begin_transaction (Begins at: 89 Ends at: 113)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
db__driver_commit_transaction (Begins at: 115 Ends at: 130)
LOC:          |      16 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-11-24 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
