[GRASS-QA] GRASS QA: carlos | ./grass6/display/d.path/main.c |no clones | 0 monsters | 1 warnings
Wed Oct 24 12:17:28 EDT 2007
Hello carlos,
ANALYSIS
display/d.path/main.c functions
main (Begins at: 30 Ends at: 217)
Complexity:   |      16 |     * |         |
CalledNBR:    |      85 |    ** | Warning |
LOC:          |     188 |     * |         |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-10-24 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
