[GRASS-QA] GRASS QA: carlos | ./grass6/raster/r.buffer/write_map.c |no clones | 0 monsters | 0 warnings
Wed Oct 24 12:17:28 EDT 2007
Hello carlos,
ANALYSIS
raster/r.buffer/write_map.c functions
write_output_map (Begins at: 28 Ends at: 92)
Complexity:   |      12 |       |      OK |
CalledNBR:    |      22 |       |      OK |
LOC:          |      65 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-10-24 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
