[GRASS-QA] GRASS QA: hamish |main.c | 8 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Sep 5 14:30:47 EDT 2008
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/raster/r.in.bin/main.c
          Function
main(Begins at: 72, Ends at:594)
              |          New Metrics           |Old Metrics|
Complexity:   |      74 |   *** |      MONSTER |        74 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |     214 |   *** |      MONSTER |       184 |
LOC:          |     523 |   *** |      MONSTER |       525 |
Conclusion:   | this function is a       MONSTER           |
metrics are OK
SwabDouble(Begins at: 53, Ends at:70)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      18 |       |           OK |        18 |
Conclusion:   | this function is a            OK           |
metrics are OK
SwabFloat(Begins at: 48, Ends at:51)
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       4 |       |           OK |         4 |
metrics are OK
SwabLong(Begins at: 35, Ends at:46)
LOC:          |      12 |       |           OK |        12 |
metrics are OK
SwabShort(Begins at: 25, Ends at:33)
LOC:          |       9 |       |           OK |         9 |
metrics are OK
Clone analysis:
This file has 8 potentially cloned functions:
  SwabDouble  SwabDouble  SwabLong  SwabLong  TIFFSwabLong  SwabLong  TIFFSwabLong
In /var/project-manager/grass/grassSVN/grass/trunk/raster/r.in.bin/main.c clones of SwabDouble are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/raster/r.in.bin/main.c  SwabDouble
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/raster/r.in.mat/main.c  SwabDouble
          /var/project-manager/grass/grassSVN/grass/trunk/raster/r.in.mat/main.c  SwabDouble
In /var/project-manager/grass/grassSVN/grass/trunk/raster/r.in.bin/main.c clones of SwabLong are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/raster/r.in.bin/main.c  SwabLong
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/raster/r.in.mat/main.c  SwabLong
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/raster/r.out.bin/tif_swab.c  TIFFSwabLong
          /var/project-manager/grass/grassSVN/grass/trunk/raster/r.in.mat/main.c  SwabLong
          /var/project-manager/grass/grassSVN/grass/trunk/raster/r.out.bin/tif_swab.c  TIFFSwabLong
____________________________________________
Threshold GRASS6 key metrics values at Fri Sep 05 14:36:10 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
