[GRASS-QA] GRASS QA: martinl |line.cpp | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Sep 5 14:32:54 EDT 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/gui/wxpython/vdigit/line.cpp
          Class
Digit(Begins at: -9999, Ends at:-9999)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |    112 |    402 |      0 |     91 |
|OLD Metrics |      1 |      0 |    112 |    402 |      0 |     91 |
          Method
AddLine(Begins at: 38, Ends at:182)
              |          New Metrics           |Old Metrics|
Complexity:   |      20 |    ** | BABY-MONSTER |        20 |
ParamNBR:     |       7 |       |           OK |         7 |
CalledNBR:    |      41 |    ** | BABY-MONSTER |        41 |
LOC:          |     145 |    ** | BABY-MONSTER |       145 |
Conclusion:   | this function is a  BABY-MONSTER           |
metrics are OK
BreakLines(Begins at: 614, Ends at:651)
Complexity:   |       8 |    ** | BABY-MONSTER |         8 |
ParamNBR:     |       0 |    ** | BABY-MONSTER |         0 |
CalledNBR:    |       9 |   *** |      MONSTER |         9 |
LOC:          |      38 |   *** |      MONSTER |        38 |
Conclusion:   | this function is a       MONSTER           |
metrics are OK
ConnectLines(Begins at: 681, Ends at:712)
Complexity:   |       5 |     * |      WARNING |         5 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      32 |       |           OK |        32 |
Conclusion:   | this function is a       WARNING           |
metrics are OK
CopyLines(Begins at: 752, Ends at:807)
Complexity:   |       9 |       |           OK |         9 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      16 |       |           OK |        16 |
LOC:          |      56 |       |           OK |        56 |
Conclusion:   | this function is a            OK           |
metrics are OK
DeleteLines(Begins at: 338, Ends at:461)
Complexity:   |      17 |     * |      WARNING |        17 |
CalledNBR:    |      27 |     * |      WARNING |        27 |
LOC:          |     124 |     * |      WARNING |       124 |
metrics are OK
FlipLines(Begins at: 532, Ends at:560)
Complexity:   |       5 |       |           OK |         5 |
ParamNBR:     |       0 |       |           OK |         0 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      29 |       |           OK |        29 |
metrics are OK
MergeLines(Begins at: 568, Ends at:604)
Complexity:   |       8 |     * |      WARNING |         8 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      37 |       |           OK |        37 |
metrics are OK
MoveLines(Begins at: 475, Ends at:524)
ParamNBR:     |       6 |       |           OK |         6 |
CalledNBR:    |       8 |     * |      WARNING |         8 |
LOC:          |      50 |       |           OK |        50 |
metrics are OK
OpenBackgroundVectorMap(Begins at: 819, Ends at:857)
Complexity:   |       6 |       |           OK |         6 |
CalledNBR:    |      14 |       |           OK |        14 |
LOC:          |      39 |       |           OK |        39 |
metrics are OK
RewriteLine(Begins at: 196, Ends at:283)
Complexity:   |      13 |       |           OK |        13 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |      20 |       |           OK |        20 |
LOC:          |      88 |       |           OK |        88 |
metrics are OK
SnapLines(Begins at: 663, Ends at:673)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      11 |       |           OK |        11 |
metrics are OK
SplitLine(Begins at: 296, Ends at:328)
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       4 |    ** | BABY-MONSTER |         4 |
LOC:          |      33 |       |           OK |        33 |
metrics are OK
TypeConvLines(Begins at: 869, Ends at:901)
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      33 |     * |      WARNING |        33 |
metrics are OK
ZBulkLabeling(Begins at: 728, Ends at:741)
Complexity:   |       2 |    ** | BABY-MONSTER |         2 |
ParamNBR:     |       6 |     * |      WARNING |         6 |
CalledNBR:    |       1 |     * |      WARNING |         1 |
LOC:          |      14 |     * |      WARNING |        14 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold GRASS6 key metrics values at Fri Sep 05 14:38:18 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
