[GRASS-QA] GRASS QA: neteler |check.c histo.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Sep 12 09:46:08 EDT 2008
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/raster/r.support.stats/check.c
          Function
check_stats(Begins at: 29, Ends at:95)
              |          New Metrics           |Old Metrics|
Complexity:   |      10 |     * |      WARNING |        10 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      24 |    ** | BABY-MONSTER |        24 |
LOC:          |      67 |     * |      WARNING |        67 |
Conclusion:   | this function is a  BABY-MONSTER           |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :grass/branches/develbranch_6/raster/r.support.stats/histo.c
          Function
do_histogram(Begins at: 27, Ends at:71)
Complexity:   |       7 |     * |      WARNING |         7 |
CalledNBR:    |      14 |     * |      WARNING |        14 |
LOC:          |      45 |     * |      WARNING |        45 |
Conclusion:   | this function is a       WARNING           |
metrics are OK
Clone analysis:
____________________________________________
Threshold GRASS6 key metrics values at Fri Sep 12 09:52:58 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Please visite our web site on your project at :http://web.soccerlab.polymtl.ca/project-manager/index.html
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
