[GRASS-QA] GRASS QA: neteler |gisdefs.h ls.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Mon Sep 15 09:58:46 EDT 2008
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/include/gisdefs.h
The system don't find class, method and function
 in this file during analysis!
          File :grass/branches/develbranch_6/lib/gis/ls.c
          Function
cmp_names(Begins at: 32, Ends at:38)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       7 |       |           OK |         7 |
Conclusion:   | this function is a            OK           |
metrics are OK
G_ls(Begins at: 94, Ends at:107)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      14 |       |           OK |        14 |
metrics are OK
G_ls_format(Begins at: 124, Ends at:185)
Complexity:   |       9 |     * |      WARNING |         9 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      62 |     * |      WARNING |        62 |
Conclusion:   | this function is a       WARNING           |
metrics are OK
G__ls(Begins at: 56, Ends at:80)
Complexity:   |       4 |       |           OK |         4 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      25 |       |           OK |        25 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold GRASS6 key metrics values at Mon Sep 15 10:06:16 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Please visite our web site on your project at :http://web.soccerlab.polymtl.ca/project-manager/index.html
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
