[GRASS-QA] GRASS QA: hamish |grass2str.h | no clones | 1 monsters |1 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Aug 10 09:45:11 EDT 2010
Hello hamish,
here's a report on your recent grass-SVN change for the revision : 42827
ANALYSIS
your changes to files/class/methods/functions :
          File :/raster/r.terraflow/grass2str.h
          Function
stream2_CELL(Begins at: 158, Ends at:496)
              |          New Metrics           |Old Metrics|
Complexity:   |      25 |    ** | BABY-MONSTER |        25 |
ParamNBR:     |      29 |   *** |      MONSTER |        29 |
CalledNBR:    |     118 |   *** |      MONSTER |       118 |
LOC:          |     339 |   *** |      MONSTER |       339 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
cell2stream(Begins at: 38, Ends at:150)
Complexity:   |      17 |     * |      WARNING |        17 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      30 |     * |      WARNING |        30 |
LOC:          |     113 |     * |      WARNING |       113 |
Conclusion:   | this function is a       WARNING           |
 at least 4 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Tue Aug 10 09:45:09 EDT 2010 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        19 |        30 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        18 |        42 |        66 |
LOC:                  |        66 |       149 |       233 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
