[GRASS-QA] GRASS QA: mmetz |main.c | 2 clones | 1 monsters |2 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Apr 8 04:35:24 EDT 2011
Hello mmetz,
here's a report on your recent grass-SVN change for the revision : 45873
ANALYSIS
your changes to files/class/methods/functions :
          File :/vector/v.buffer/main.c
          Class
buf_contours(Begins at: 72, Ends at:77)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Function
get_line_box(Begins at: 120, Ends at:159)
              |          New Metrics           |Old Metrics|
Complexity:   |       9 |     * |      WARNING |         9 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      40 |       |           OK |        40 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
point_in_buffer(Begins at: 79, Ends at:118)
Complexity:   |       7 |       |           OK |         7 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       4 |       |           OK |         4 |
main(Begins at: 161, Ends at:731)
Complexity:   |      66 |   *** |      MONSTER |        66 |
CalledNBR:    |     230 |   *** |      MONSTER |       230 |
LOC:          |     571 |   *** |      MONSTER |       571 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file has 2 potentially cloned functions:
  point_in_buffer
In /data/project-manager/grass/grassSVN/grass/trunk/vector/v.buffer/main.c clones of get_line_box are:
          /data/project-manager/grass/grassSVN/grass/trunk/lib/vector/diglib/box.c  dig_line_box
In /data/project-manager/grass/grassSVN/grass/trunk/vector/v.buffer/main.c clones of point_in_buffer are:
          /var/project-manager/grass/grassSVN/grass/trunk/vector/v.buffer/main.c  point_in_buffer
____________________________________________
Threshold grass key metrics values at Fri Apr 08 04:35:22 EDT 2011 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         9 |        21 |        33 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        16 |        38 |        61 |
LOC:                  |        63 |       142 |       222 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
