[STATSGRASS] ORDINARY KRIGING IN R WITH GRASS6 DATA
epifanio epi massimodisasha at yahoo.it
Fri Apr 7 09:23:02 EDT 2006
i'm trying to use the ORDINARY KRIGING IN R WITH GRASS6 DATA
i've in a grass location a vector file ( type : point) its name is :
vector_point
i open R and type :
 > library(spgrass6)
Carico il pacchetto richiesto: rgdal
Carico il pacchetto richiesto: sp
Carico il pacchetto richiesto: abind
Carico il pacchetto richiesto: pixmap
Geospatial Data Abstraction Library extensions to R successfully loaded
Warning message:
cannot create HTML package index in: make.packages.html()
then as the example at the web page :
http://grass.gdf-hannover.de/twiki/pub/GRASS/WebHome/
krigingusingRGRASS6.txt
i type :
 > giaciture <- getSites6sp("vector_point")
Errore: non trovo la funzione "getSites6sp"
why R do not find :  getSites6sp - function ?
canyou helpe me ?
thank's!
Massimo
More information about the grass-stats mailing list
