[STATSGRASS] ORDINARY KRIGING IN R WITH GRASS6 DATA
Roger Bivand Roger.Bivand at nhh.no
Fri Apr 7 09:41:54 EDT 2006
On Fri, 7 Apr 2006, epifanio epi wrote:
> i'm trying to use the ORDINARY KRIGING IN R WITH GRASS6 DATA
> i've in a grass location a vector file ( type : point) its name is :
> vector_point
> i open R and type :
>  > library(spgrass6)
> Carico il pacchetto richiesto: rgdal
> Carico il pacchetto richiesto: sp
> Carico il pacchetto richiesto: abind
> Carico il pacchetto richiesto: pixmap
> Geospatial Data Abstraction Library extensions to R successfully loaded
> Warning message:
> cannot create HTML package index in: make.packages.html()
> then as the example at the web page :
> http://grass.gdf-hannover.de/twiki/pub/GRASS/WebHome/
> krigingusingRGRASS6.txt
> i type :
Please report the output of sessionInfo() - if your copy of the spgrass6
package is not 0.1-6, that may be the reason.
>  > giaciture <- getSites6sp("vector_point")
> Errore: non trovo la funzione "getSites6sp"
> why R do not find :  getSites6sp - function ?
> canyou helpe me ?
> thank's!
> Massimo
> statsgrass mailing list
> statsgrass at grass.itc.it
> http://grass.itc.it/mailman/listinfo/statsgrass
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats mailing list
