[STATSGRASS] The gstat R library's: memory problem
Edzer J. Pebesma e.pebesma at geo.uu.nl
Thu Aug 24 10:47:24 EDT 2006
Pierluigi De Rosa wrote:
> Dear all users of gstat
> I'm using the gstat library for univariate geostatistics analysis,
> I have to interpolate with kriging value of water level from wells to evaluate
> the water table.
> I use the univarsal kriging and the indipendent variable is the digital
> elevation model (DEM)
> If I use a DEM with resolution of 20 mt I have an error memory
> This is the string command I use for do that:
> OK_res20=krige(LEV_MAG91~DEM,loc=pozzi91_meno,newdata=DEM20,model=vgm_fit_mag91_DEM)
> This is the error I have
> Error: cannot allocate vector of size 3995610 Kb
> If I use a DEM with resolution of 30 mt (using r.resample.rst)
> (This is the string)
> OK_res30=krige(LEV_MAG91~DEM,loc=pozzi91_meno,newdata=DEM30,model=vgm_fit_mag91_DEM)
> every thinks works ok, is this a bug?? Maybe  Dr. Pebesma can help me!! :-)
Perhaps he can, but remember he isn't a daily grass user. I doubt it is
a bug because you do get a clear error message: you (through how you use
gstat) ask the computer more memory than your computer has available,
and that's what you are told. The question is why.
Without the commands how you retrieved your data and of what size
(number of rows and columns) they are there is little I can do, from
here, however.
Edzer
> Thanks, Pierluigi
> P.S.
> this is my region setting
> g.region -p
> projection: 99 (Transverse Mercator)
> zone:       0
> datum:      rome40
> ellipsoid:  international
> north:      4829500
> south:      4813540
> west:       2280740
> east:       2298420
> nsres:      20
> ewres:      20
> rows:       798
> cols:       884
> Pierluigi De Rosa
> Department of Enviromental & Civil engineering
> Faculty of Engineering
> Perugia (Italy)
> statsgrass mailing list
> statsgrass at grass.itc.it
> http://grass.itc.it/mailman/listinfo/statsgrass
More information about the grass-stats mailing list
