[STATSGRASS] The gstat R library's: memory problem
Roger Bivand Roger.Bivand at nhh.no
Thu Aug 24 12:36:35 EDT 2006
On Thu, 24 Aug 2006, Edzer J. Pebesma wrote:
> Pierluigi De Rosa wrote:
> > Dear all users of gstat
I think it is maxdist= again, or some other way of reducing the size. The
GRASS region is roughly 800 by 900, but the sizes of both the data and
newdata are unknown. Pierluigi also cross-posted, which does indicate a
propensity to appeal for help rather than to look at the archives. Using
the search facility on the GRASS site with "gstat memory", there were lots
of promising hits from this list just in the last few months.
> > I'm using the gstat library for univariate geostatistics analysis,
> > I have to interpolate with kriging value of water level from wells to evaluate
> > the water table.
> > I use the univarsal kriging and the indipendent variable is the digital
> > elevation model (DEM)
> > If I use a DEM with resolution of 20 mt I have an error memory
> > This is the string command I use for do that:
> > OK_res20=krige(LEV_MAG91~DEM,loc=pozzi91_meno,newdata=DEM20,model=vgm_fit_mag91_DEM)
> > This is the error I have
> > Error: cannot allocate vector of size 3995610 Kb
> > If I use a DEM with resolution of 30 mt (using r.resample.rst)
> > (This is the string)
> > OK_res30=krige(LEV_MAG91~DEM,loc=pozzi91_meno,newdata=DEM30,model=vgm_fit_mag91_DEM)
> > every thinks works ok, is this a bug?? Maybe  Dr. Pebesma can help me!! :-)
> Perhaps he can, but remember he isn't a daily grass user. I doubt it is
> a bug because you do get a clear error message: you (through how you use
> gstat) ask the computer more memory than your computer has available,
> and that's what you are told. The question is why.
> Without the commands how you retrieved your data and of what size
> (number of rows and columns) they are there is little I can do, from
> here, however.
> Edzer
> > Thanks, Pierluigi
> > P.S.
> > this is my region setting
> > g.region -p
> > projection: 99 (Transverse Mercator)
> > zone:       0
> > datum:      rome40
> > ellipsoid:  international
> > north:      4829500
> > south:      4813540
> > west:       2280740
> > east:       2298420
> > nsres:      20
> > ewres:      20
> > rows:       798
> > cols:       884
> > Pierluigi De Rosa
> > Department of Enviromental & Civil engineering
> > Faculty of Engineering
> > Perugia (Italy)
> > statsgrass mailing list
> > statsgrass at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/statsgrass
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats mailing list
