[STATSGRASS] OT: sgeostat and Rdbi - conflict? (on R) SOLVED
Jarek Jasiewicz jarekj at amu.edu.pl
Sun Aug 27 14:06:06 EDT 2006
Roger Bivand napisa?(a):
> On Sun, 27 Aug 2006, Jarek Jasiewicz wrote:
>> on R, soon after I instaled sgeostat Rdbi cannot be loaded with message:
> Not sgeostat, but probably version conflict in Rdbi. Please include the
> output of sessionInfo() after loading sgeostat, and any information you
> can see from the DESCRIPTION file in the directory with the installed Rdbi
> about builds and versions.
>>> library(Rdbi)
>> Loading required package: Rdbi
>> Error in loadNamespace(package, c(which.lib.loc, lib.loc), keep.source = keep.source) :
>>         cyclic name space dependencies are not supported
>> Error: package 'Rdbi' could not be loaded
>> Error: .onLoad failed in 'loadNamespace' for 'Rdbi'
>> erlier Rdbi worked fine
>> regards
>> jarek
>> statsgrass mailing list
>> statsgrass at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/statsgrass
sorry, I sloved this problem deleting Rdata from my $HOME directory,
after that all works OK again. Probably something goes wrong during
instalation sgeostat and has been written in saved worspace. In addition
load packages from cran (tcltk gui) also has'n work even ater full
reinstaling of R.
Enyway something was wrong in saved workspace (Rdata) but now we will
not know....
regards
Jarek Jasiewicz
More information about the grass-stats mailing list
