[STATSGRASS] problem with RdbiPgSQL c.d.
Jarek Jasiewicz jarekj at amu.edu.pl
Wed Aug 30 14:09:56 EDT 2006
Roger Bivand napisa?(a):
> On Sun, 27 Aug 2006, Jarek Jasiewicz wrote:
>> on R, soon after I instaled sgeostat Rdbi cannot be loaded with message:
> Not sgeostat, but probably version conflict in Rdbi. Please include the
> output of sessionInfo() after loading sgeostat, and any information you
> can see from the DESCRIPTION file in the directory with the installed Rdbi
> about builds and versions.
>>> library(Rdbi)
>> Loading required package: Rdbi
>> Error in loadNamespace(package, c(which.lib.loc, lib.loc), keep.source = keep.source) :
>>         cyclic name space dependencies are not supported
>> Error: package 'Rdbi' could not be loaded
>> Error: .onLoad failed in 'loadNamespace' for 'Rdbi'
>> erlier Rdbi worked fine
>> regards
>> jarek
>> statsgrass mailing list
>> statsgrass at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/statsgrass
Unfortunatly the problem is NOT solved..
The problem concering only RdbiPgSQL. sgeostat has no inlfluence... I
did the following:
1) install R (2.3.1 from source)
2) install spgrass6, from your instruciton
3) install RdbiPgSQL according Marcus instruction
all successed.
4) I load RdbiPgSQL library(RdbiPgSQL)... All OK
5) do something... (lada data, manipulate and so on...
6 leave R without saving workspace
7) start R again load RdbiPgSQL ...All OK
8)do something (some objects are created) and leave R WITH SAVING workspace
9) load R again - ls() ...previous objects exit
10) try to load library(RdbiPgSQL): error
...and of course no function Rdbi works
11)Again remove .Rdata from $home directory
12)start R again and library(RdbiPgSQL) works nice
so i thing some problem is with R workspace and information stored within.
Here is th "working" session info
Version 2.3.1 (2006-06-01)
i686-pc-linux-gnu
attached base packages:
[1] "methods" "stats" "graphics" "grDevices" "utils" "datasets"
[7] "tcltk" "base"
other attached packages:
spgrass6 rgdal maptools foreign gstat sp RdbiPgSQL Rdbi
"0.3-1" "0.4-8" "0.5-12" "0.8-15" "0.9-31" "0.8-18" "1.7.2" "1.7.0"
Regards
Jarek Jasiewicz
More information about the grass-stats mailing list
