[STATSGRASS] problem with installing rgdal FAIL
Roger Bivand Roger.Bivand at nhh.no
Wed Sep 6 12:28:11 EDT 2006
On Wed, 6 Sep 2006, [windows-1252] Jaros?aw Jasiewicz wrote:
> well.... failed
> I did folowing step-by step, and always I receved the mentioned message
Your /usr/local/lib is identical with mine, and for me no
--configure-args='' are needed in any case. I cannot debug your setup
directly, so you'll need to unpack rgdal_0.4-10.tar.gz, and edit
configure.in (putting in echo of shell variables of interest), run
autoconf, and see how you go. You can try sh -x configure as well as
./configure. I'm sorry I can't help more, but I don't have a system like
yours, so cannot replicate.
Roger
> the last command was:
>  sudo R CMD INSTALL -l /usr/local/lib/R/library/
> --configure-args='--with-proj-include=/usr/local/include
> --with-proj-lib=/usr/local/lib' rgdal_0.4-10.tar.gz
> and here a full listing of my /usr/local/lib folder, Is something missing?
> -rw-r--r--  1 root root  5865748 2006-09-04 11:13 libgdal.a
> -rwxr-xr-x  1 root root     1117 2006-09-04 11:13 libgdal.la
> lrwxrwxrwx  1 root root       17 2006-09-04 11:13 libgdal.so ->
> libgdal.so.1.10.0
> lrwxrwxrwx  1 root root       17 2006-09-04 11:13 libgdal.so.1 ->
> libgdal.so.1.10.0
> -rwxr-xr-x  1 root root  4368728 2006-09-04 11:13 libgdal.so.1.10.0
> -rw-r--r--  1 root root  1182320 2006-09-05 09:48 libproj.a
> -rwxr-xr-x  1 root root      794 2006-09-05 09:48 libproj.la
> lrwxrwxrwx  1 root root       16 2006-09-05 09:48 libproj.so ->
> libproj.so.0.5.0lrwxrwxrwx  1 root root       16 2006-09-05 09:48
> libproj.so.0 -> libproj.so.0.5.0
> -rwxr-xr-x  1 root root   671206 2006-09-05 09:48 libproj.so.0.5.0
> drwxrwsr-x  3 root staff    4096 2006-08-06 01:19 python2.4
> drwxr-xr-x 10 root root     4096 2006-09-04 11:44 R
> of course gdal, and geos has been instaled without help, only simple
> ./configure
> grass has need some help but concering tcltk and postgres (and cxx motif
> and readline)
> regards
> Jarek
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats mailing list
