[STATSGRASS] problem with installing rgdal FAIL
Jaros?aw Jasiewicz jarekj at amu.edu.pl
Wed Sep 6 05:45:46 EDT 2006
well.... failed
I did folowing step-by step, and always I receved the mentioned message
the last command was:
 sudo R CMD INSTALL -l /usr/local/lib/R/library/
--configure-args='--with-proj-include=/usr/local/include
--with-proj-lib=/usr/local/lib' rgdal_0.4-10.tar.gz
and here a full listing of my /usr/local/lib folder, Is something missing?
-rw-r--r--  1 root root  5865748 2006-09-04 11:13 libgdal.a
-rwxr-xr-x  1 root root     1117 2006-09-04 11:13 libgdal.la
lrwxrwxrwx  1 root root       17 2006-09-04 11:13 libgdal.so ->
libgdal.so.1.10.0
lrwxrwxrwx  1 root root       17 2006-09-04 11:13 libgdal.so.1 ->
libgdal.so.1.10.0
-rwxr-xr-x  1 root root  4368728 2006-09-04 11:13 libgdal.so.1.10.0
-rw-r--r--  1 root root  1182320 2006-09-05 09:48 libproj.a
-rwxr-xr-x  1 root root      794 2006-09-05 09:48 libproj.la
lrwxrwxrwx  1 root root       16 2006-09-05 09:48 libproj.so ->
libproj.so.0.5.0lrwxrwxrwx  1 root root       16 2006-09-05 09:48
libproj.so.0 -> libproj.so.0.5.0
-rwxr-xr-x  1 root root   671206 2006-09-05 09:48 libproj.so.0.5.0
drwxrwsr-x  3 root staff    4096 2006-08-06 01:19 python2.4
drwxr-xr-x 10 root root     4096 2006-09-04 11:44 R
of course gdal, and geos has been instaled without help, only simple
./configure
grass has need some help but concering tcltk and postgres (and cxx motif
and readline)
regards
Jarek
More information about the grass-stats mailing list
