[STATSGRASS] problem with installing rgdal (to Roger, I thing)
Roger Bivand Roger.Bivand at nhh.no
Tue Sep 5 06:28:08 EDT 2006
On Tue, 5 Sep 2006, [ISO-8859-2] Jaros³aw Jasiewicz wrote:
> I try to install rgdal 0.4-10 on another computer (ubuntu 6.06, R 2.3.1
> from sources)
> and I recive massage:
> > checking proj_api.h presence... yes
> > checking for proj_api.h... yes
> > checking for pj_init_plus in -lproj... no
> > libproj.a and/or proj_api.h not found.
> > If the PROJ.4 library is installed in a non-standard location,
> > use --configure-args='--with-proj-include=/opt/local/include
> > --with-proj-lib=/opt/local/lib' for example, replacing /opt/local/*
> > with appropriate values for your installation.
> > If PROJ.4 is not installed, install it.
> > ERROR: configuration failed for package 'rgdal'
> > ** Removing '/usr/local/lib/R/library/rgdal'
> Of course, I cannot add, I have proj4 installed porertly in:
> usr/local/share/proj4, usr/local/lib and usr/local/include
> (to avoid questions - beleve me, I know how proj4 shall be installed
> propertly)
> the proj_api.h is in usr/local/include and libproj.a is in usr/local lib
> next according message I try
> install.packages("rgdal", repos="http://...",
> configure.args=c('--with-proj-lib=/usr/local/lib',
> '--with-proj-include=/usr/local/include'))
> I recived the same message
> Because /usr/local/... for some programs are not standard instalation
> path (in spite of it it is on PATH) i have installed proj4 from ubuntu
> repository to /usr/lib, usr/share/proj4 and /usr/include
> and I recived the same message
> In my home compurer, where I had installed rgdal 0.4-8 before
> installation was without problems (problems are with sperfish60 and
> other unprojected locations but it isn't a theme of that post)
> I know that configure.args is not proper. It shall be with variables but
> I don't know which (LD_LIBRARY_PATH LD_INCLUDE_PATH taht not work??)
Please do things step by step, it will be easier to help.
Please download the rgdal_0.4-10.tar.gz file to a suitable temporary
directory. Change to that directory and run
R CMD INSTALL -l <your R_LIBS> rgdal_0.4-10.tar.gz
from the shell prompt by hand. If the same error occurs, follow:
http://www.sal.uiuc.edu/tools/tools-sum/rgeo/rgeo-detail/map-packages-on-cran
and
http://cran.r-project.org/doc/manuals/R-exts.html#Configure-example
carefully in building up the --configure-args='' to suit your
installation, probably:
--configure-args='--with-proj-lib=/usr/local/lib'
I do not know how Ubuntu sets up the environment for ./configure, in your
case the headers are being found but not the lib*.a file, which is
puzzling, because /usr/local is a usual place to look by default. Does
GDAL find the PROJ.4 headers and libraries without help?
Hope this helps.
Roger
> And in addition. I don't know it is connected - but few second after
> mentioned error computers resources going to 0 (I cannot try which
> application) and R stops with message: cannot allocate 27 bytes...
> others libraries (include PgSQL was instaslled without problems)
Problems are known to occur when the archive address is wrong, etc.
> statsgrass mailing list
> statsgrass at grass.itc.it
> http://grass.itc.it/mailman/listinfo/statsgrass
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats mailing list
