[STATSGRASS] RE: [GRASS-user] kriging
Markus Neteler neteler at itc.it
Mon Sep 25 08:07:55 EDT 2006
Maciej Sieczka wrote on 09/25/2006 12:12 PM:
> ehizcara at agrogex.com wrote:
>>> Eduardo, thanks a lot. Before I decide what will I use - what about applying
>>> fault lines? Is it possible to incorporate those as lines where stops
>>> interpolations?
> The only FOSS I know that supports fault lines (if that's what you
> mean) is Surfit http://surfit.sourceforge.net
> Examples: http://surfit.sourceforge.net/surfit/examples.html.
> Maciek
Luckily GRASS can do that, too:
http://mpa.itc.it/markus/grass61/demos/gully_surf_rst.jpg
... taken from our GRASS book,
 section 7.3.5 Surfaces with faults.
(if you have the 1st edition, see also related erratum:
 http://mpa.itc.it/grasstutor/errata_menu.phtml)
Cheers
Markus
More information about the grass-stats mailing list
