[STATSGRASS] RE: [GRASS-user] kriging
Maciej Sieczka tutey at o2.pl
Mon Sep 25 08:35:32 EDT 2006
Markus Neteler wrote:
> Maciej Sieczka wrote on 09/25/2006 12:12 PM:
>> ehizcara at agrogex.com wrote:
>>>> Eduardo, thanks a lot. Before I decide what will I use - what about applying
>>>> fault lines? Is it possible to incorporate those as lines where stops
>>>> interpolations?
>> The only FOSS I know that supports fault lines (if that's what you
>> mean) is Surfit http://surfit.sourceforge.net
>> Examples: http://surfit.sourceforge.net/surfit/examples.html.
>> Maciek
> Luckily GRASS can do that, too:
> http://mpa.itc.it/markus/grass61/demos/gully_surf_rst.jpg
> .. taken from our GRASS book,
>  section 7.3.5 Surfaces with faults.
Markus,
That's not the same. I don't you can achieve this:
http://surfit.sourceforge.net/surfit/fault_8tcl-example.html
http://surfit.sourceforge.net/surfit/fault__approx_8tcl-example.html
using Grass. In Grass you can't use lines as interpolation faults. The
method you refer to uses area masking, and it can't reproduce the
Surfit examples.
Maciek
More information about the grass-stats mailing list
