[STATSGRASS] gstat: problem with prediction value at point location
Edzer J. Pebesma e.pebesma at geo.uu.nl
Tue Jan 23 02:30:17 EST 2007
My guess is that the technique you're referring to (and used by
Geostatistical Analyst, afaik) is [kriging in] cross
validation---observations are left out to obtain a kriging estimate for
which it makes sense to compare it with the observation. Definitely
distinct from kriging, which does not leave observations out.
Edzer
Jarosław Jasiewicz wrote:
> Edzer J. Pebesma napisał(a):
>> This is a well-known property of kriging if locations coincide
>> exactly: if measured, the best estimate is the measurement itself.
> Hmm. yes and no. As I remember form other program (like geostatistic
> analist in arc info) in point value wasn't exact. the difference
> between exact and predicted values in point location were used to
> calculate the RMS total (I can be wrong here, I didn't used Arc Info
> for over 2 years) before final calculation.
> I I attached samples, how it looks like with point location.
> It was found  during disscution when I presended some data. I was
> asked about RMS Total for my prediction (in arc info mode  - as sum of
> differences between exact and predicted values in point location). I
> tried to do this with sampling points at predicted map. In that way
> the RMS Total was 0!. I consult result with others and it seems
> variogram is OK,
> (it was automatically fitted expotential vaiogram, for gaussian
> variogram result was worse).
>> It's also cause of the problem that you can't have duplicate
>> observations in kriging. Even with a nugget, gamma(0)=0. You may want
>> to shift your points or your grid e.g. a few centimeters to get rid
>> of it.
> it gives the same results
> regards
> Jarek
More information about the grass-stats mailing list
