[STATSGRASS] gstat: problem with prediction value at point location
Jarosław Jasiewicz jarekj at amu.edu.pl
Tue Jan 23 02:25:27 EST 2007
Edzer J. Pebesma napisał(a):
> This is a well-known property of kriging if locations coincide
> exactly: if measured, the best estimate is the measurement itself.
Hmm. yes and no. As I remember form other program (like geostatistic
analist in arc info) in point value wasn't exact. the difference between
exact and predicted values in point location were used to calculate the
RMS total (I can be wrong here, I didn't used Arc Info for over 2 years)
before final calculation.
I I attached samples, how it looks like with point location.
It was found  during disscution when I presended some data. I was asked
about RMS Total for my prediction (in arc info mode  - as sum of
differences between exact and predicted values in point location). I
tried to do this with sampling points at predicted map. In that way the
RMS Total was 0!. I consult result with others and it seems variogram is
OK,
(it was automatically fitted expotential vaiogram, for gaussian
variogram result was worse).
> It's also cause of the problem that you can't have duplicate
> observations in kriging. Even with a nugget, gamma(0)=0. You may want
> to shift your points or your grid e.g. a few centimeters to get rid of
> it.
it gives the same results
 regards
Jarek
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-stats/attachments/20070123/08c56f0f/krig.jpg
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-stats/attachments/20070123/08c56f0f/krigp.jpg
More information about the grass-stats mailing list
