[STATSGRASS] gstat: problem with prediction value at point location
Edzer J. Pebesma e.pebesma at geo.uu.nl
Mon Jan 22 15:11:25 EST 2007
This is a well-known property of kriging if locations coincide exactly:
if measured, the best estimate is the measurement itself. It's also
cause of the problem that you can't have duplicate observations in
kriging. Even with a nugget, gamma(0)=0. You may want to shift your
points or your grid e.g. a few centimeters to get rid of it.
Edzer
Jarek Jasiewicz wrote:
> Hi
> when I tested prediction values kirging result I found that values at
> pixel exactly at point location has the same values as points. It
> gives that in points appear thin peaks with values strongly different
> from neigbours. It looks like gstat do not use prediction values but
> used exact values.
> Variogram I used had the nugget
> Jarek
> statsgrass mailing list
> statsgrass at grass.itc.it
> http://grass.itc.it/mailman/listinfo/statsgrass
More information about the grass-stats mailing list
