[STATSGRASS] gstat: problem with prediction value at point location
Jarek Jasiewicz jarekj at amu.edu.pl
Mon Jan 22 14:49:16 EST 2007
Hi
when I tested prediction values kirging result I found that values at
pixel exactly at point location has the same values as points. It gives
that in points appear thin peaks with values strongly different from
neigbours. It looks like gstat do not use prediction values but used
exact values.
Variogram I used had the nugget
Jarek
More information about the grass-stats mailing list
