[STATSGRASS] gstat: problem with prediction value at point location
Jarosław Jasiewicz jarekj at amu.edu.pl
Tue Jan 23 09:11:57 EST 2007
Roger Bivand napisał(a):
> On Tue, 23 Jan 2007, Edzer J. Pebesma wrote:
>> My guess is that the technique you're referring to (and used by
>> Geostatistical Analyst, afaik) is [kriging in] cross
>> validation---observations are left out to obtain a kriging estimate for
>> which it makes sense to compare it with the observation. Definitely
>> distinct from kriging, which does not leave observations out.
> When run head to head, gstat CV LOO (leave one out) on trend surfaces and
> GA give the same results, so, yes, GA seems by default to do LOO CV.
> Roger
Sorry I didn't uderstand that...
Jarek
More information about the grass-stats mailing list
