[STATSGRASS] gstat: witdh tolerance for non-regular space points?
Carlos "Guâno" Grohmann carlos.grohmann at gmail.com
Tue Jan 23 16:14:16 EST 2007
I was doing some tests on interpolating DEM data, and since gstat is
giving errors in lat-long regions, I decided to convert the DEM to
vector points, project the points to UTM and then kriging the
projected points. The thing is that now my points are no longer
regularly spaced, (as in square cells) but like rectangular cells.
I was thinking, can I use some kind of tolerance for the width
distance in variogram() function? with this I would be able to use all
the points in my dataset, because if I use a fixed width, some of the
points won't be used.
Carlos
              Carlos Henrique Grohmann - Guano
  Geologist M.Sc  - Doctorate Student at IGc-USP - Brazil
Linux User #89721  - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
More information about the grass-stats mailing list
