[STATSGRASS] gstat: problem with prediction value at point location
Jarek Jasiewicz jarekj at amu.edu.pl
Tue Jan 23 12:08:54 EST 2007
Roger Bivand napisa?(a):
> On Tue, 23 Jan 2007, [UTF-8] Jarosław Jasiewicz wrote:
>> Roger Bivand napisał(a):
>>> On Tue, 23 Jan 2007, Edzer J. Pebesma wrote:
>>>> My guess is that the technique you're referring to (and used by
>>>> Geostatistical Analyst, afaik) is [kriging in] cross
>>>> validation---observations are left out to obtain a kriging estimate for
>>>> which it makes sense to compare it with the observation. Definitely
>>>> distinct from kriging, which does not leave observations out.
>>> When run head to head, gstat CV LOO (leave one out) on trend surfaces and
>>> GA give the same results, so, yes, GA seems by default to do LOO CV.
> Leave-one-out cross validation is when you make a prediction for data
> point j, using the data for point i=1,...,n; i!=j (leave out j). That
> means that you can validly compare the observed value at j with its
> prediction made using all the rest of the data (and the same variogram
> model for all cases). Then you do RMSE on the LOO CV residuals. See
> ?gstat.cv in the gstat package.
> Roger
>>> Roger
>> Sorry I didn't uderstand that...
>> Jarek
thanks, all clear
reagrds
Jarek
More information about the grass-stats mailing list
