[STATSGRASS] Re: gmeta6() returns empty string
Roger Bivand Roger.Bivand at nhh.no
Thu Mar 1 07:51:07 EST 2007
On Thu, 1 Mar 2007, Tilmann Steinmetz wrote:
> Hi Roger and all,
> > Very strange, maybe when Stromboli calms down?
> I'm still covered with tephra but starting to see clearer: I tried executing
> system("g.region -p") in R on a similar machine, running R 2.2.1 on FreeBSD
> 5.4 and GRASS6.0.2,2 which _does not_ have similar problems- so the shell
> thing definitely is not a general FreeBSD problem. I am still thankful for
> every hint that may lead to the wanted rogue environment variable or
> whatever.
G_gettext is also in GRASS 6.0.2, I just checked.
> > > Is there any way I can go from here without running Grass on,
> > say, Linux?
> > Yes, of course. Just run them side-by-side, with GRASS using
> > r.in.gdal and
> > v.in.ogr to read files written from R by writeGDAL() and writeOGR()
> > in
> > rgdal, and r.out.* and v.out.ogr wrt. readOGR() and readGDAL() in
> > rgdal in
> oh great! I wasn't aware of that.
Then that may be the easiest way to go forward.
> > R. This is almost what the interface does anyway, but because the
> > new
> > stand-alone r.out.gdal is in 6.3, you may need to choose your
> > prefered 6.2
> > raster output format avoiding the older scripted r.out.gdal if you
> > are not
> > running the GDAL GRASS plugin (best not to, IMO). All the interface
> > gives
> > over and above this is handling the intermediate files as temporary
> > files,
> > and adding GRASS categories as factor levels to R factors.
> > How did you install R, I assume you built from source? Did you
> > notice any
> > worrying messages?
> yes - it was installed from the FreeBSD ports collection (i.e. a source
> install which resolves dependencies, or: is meant to ..) I am now updating -
> lets see what happens.
OK. Please say if you see anything there. The r.out.gdal in GRASS 6.3 is a
big improvement over the scripted version in GRASS 6.2 and earlier.
Roger
> Tilmann
> > > ----- Originalnachricht -----
> > > Von: Roger Bivand <Roger.Bivand at nhh.no>
> > > Datum: Mittwoch, Februar 28, 2007 14:46
> > > Betreff: Re: WG: Re: WG: Re: gmeta6() returns empty string
> > > An: Tilmann Steinmetz <tilmann.steinmetz at geo.uni-halle.de>
> > > > Does this usually correlate with activity on Stromboli?
> > > "g.list rast" rather points to rushmore or even better: bugsites :}
> > Roger Bivand
> > Economic Geography Section, Department of Economics, Norwegian
> > School of
> > Economics and Business Administration, Helleveien 30, N-5045 Bergen,
> > Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
> > e-mail: Roger.Bivand at nhh.no
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
More information about the grass-stats mailing list
