No subject
Wed Nov 14 16:58:11 EST 2007
//Pauls reply to me
You don't say which ellipsoid your latitude/longitude co-ordinates refer
to. Seeing you mention EUREF89 in the next paragraph I will assume it is
the GRS80... according to
http://crs.ifag.de/country_select.php?country=DK
then your command line with datum transformation parameters would be
something a bit like
cs2cs +proj=latlong +ellps=GRS80 +towgs84=0,0,0 +to +proj=utm +zone=32 \
+ellps=intl +towgs84=-81.1,-89.4,-115.8,0.485,0.024,0.413,-0.54
// My reply to Paul
Hi Paul
THANKS !!! I was using proj4 directly, not the cs2cs program. The
ellipsoid used is actually WGS84, but entering this into your golden
command line fixes my problem. If your currious heres what I get from my
comparison:
In-put coordinate:  10.138618  56.342032
Outputs:
MapInfo  : 570466.57247057 6244935.6590597    (According to MapInfo they
have an error)
KMS Trans: 570464.297      6244936.971        (Official Danish program
Thingy :-) )
cs2cs    : 570464.18       6244937.01	    (Pauls Golden Line)
PERFECT !
Thanks a lot !!
Best regards,
-Torben
The commandline used:
cs2cs +proj=latlong +ellps=WGS84 +towgs84=0,0,0 +to +proj=utm +zone=32
//END
-----Oprindelig meddelelse-----
Fra: statsgrass-admin at grass.itc.it
[mailto:statsgrass-admin at grass.itc.it] På vegne af Roger Bivand
Sendt: 24 October 2003 21:10
Til: Torben Bach
Cc: statsgrass at grass.itc.it
Emne: Re: [STATSGRASS] Proj4
On Thu, 23 Oct 2003, Torben Bach wrote:
> Hi
> Completely new to the subject I have been roaming the internet trying
> to find a "golden" command line to proj4 for converting lat-lon
> coordinates to DANISH ED50 UTM zone 32N. Apparently the internal ED50
> is not the same as the Danish (or german or french...) ED50 - im am
> confused - does anybody know the "golden" command line I so badly long
> for ?
Maybe ask on the proj list? Does the inverse transformation on
http://www.kms.dk/research/geodesy/reference/cotrans1_en.html
help?
> Another question - how accurate is the ouput from Proj4 ? I have
> compared results converting to EUREF89 with output from programs from
> the national Ministry of the Environment (KMS) handling this stuf and
> MapInfo, and they gave the same result within a meter or so. But using
> ED50 and Proj4 gave coordinates lying hundreds of meters from MapInfo
> and "official" KMS  results (this was how I discoverd I needed the
> "golden" command line).
> Thanks in advance !!
> Best regards,
> -Torben Bach
> statsgrass mailing list
> http://grass.itc.it/mailman/listinfo/statsgrass
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Breiviksveien 40, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 93 93
e-mail: Roger.Bivand at nhh.no
statsgrass at grass.itc.it http://grass.itc.it/mailman/listinfo/statsgrass
More information about the grass-stats mailing list
