[GRASS-stats] Load data multiple data from grass to R
Roger Bivand Roger.Bivand at nhh.no
Thu Nov 22 03:37:09 EST 2007
On Thu, 22 Nov 2007, Jarek Jasiewicz wrote:
> Roger Bivand wrote:
>>  On Wed, 21 Nov 2007, Jarek Jasiewicz wrote:
>> >  I'd like to write R sript to read more rasters from grass to R and
>> >  writeh them to objects with unique
>> >  what I try to do:
>> >  system("g.mlist type=rast pattern=a_* >tmp_file")
>> >  k=c(scan("temp_file, what="string")) //maybe is simpler way
>> >  for (i in k) {
>> >  here_I_need_obect_with_unique_name=readRAST6(i, paste(i))
>> >  operations_on_obiects
>>  Could you use the fact that the first argument to readRAST6() can be a
>>  character vector of raster layer names? If k is such a character vector,
>>  you could try readRAST6(k). The second argument is a logical vector, not
>>  vname= as you seem to think - that is in writeRAST6().
>>  Hope this helps,
>>  Roger
>>  obiect <-readRAST6(k)
> well maybe presented problem not enough clear
> First - there is en mistake in code i typed
> shuoud be:
> for (i in k) {
> here_I_need_obect_with_unique_name=readRAST6(i)
> but in that way I recive obiect which every iteration will be overwritten by
> nex raster map. At the end I will have obiect with last raster map in string
> vector
> How to preserve obiect created in the loop and control its name?
> I think about something like this (for example) in the loop ??
What I suggested was putting all the rasters into the same object - their
names become the column names of the object. Since the current region is
respected, they will be conformal. If you want multiple objects, use
assign() which takes a character string as the name if the object being
assigned to, but watch the scoping if you are doing this in a function.
Roger
> ob_a=readRAST6("a")
> ob_b=readRAST6("b")
> ob_c=readRAST6("c")
> ob_z=readRAST6("z")
> if I use this
> there will be the problem with converting every layer (I mean:
> "obiect at data$raster_name" i SpGridDataFrame) in multilayer SpGridDataFrame to
> "im" class obiect
> In general it is the problem how to control names of obiect if in the loop we
> need to create more than one obiect
> Hope I presented it clear
> greetings
> Jarek
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats mailing list
