[GRASS-stats] Load data multiple data from grass to R
Jarek Jasiewicz jarekj at amu.edu.pl
Thu Nov 22 03:49:23 EST 2007
Roger Bivand wrote:
> On Thu, 22 Nov 2007, Jarek Jasiewicz wrote:
>> Roger Bivand wrote:
>>>  On Wed, 21 Nov 2007, Jarek Jasiewicz wrote:
>>> >  I'd like to write R sript to read more rasters from grass to R
>>> and >  writeh them to objects with unique
>>> > >  what I try to do:
>>> > >  system("g.mlist type=rast pattern=a_* >tmp_file")
>>> >  k=c(scan("temp_file, what="string")) //maybe is simpler way
>>> > >  for (i in k) {
>>> >  here_I_need_obect_with_unique_name=readRAST6(i, paste(i))
>>> >  operations_on_obiects
>>>  Could you use the fact that the first argument to readRAST6() can be a
>>>  character vector of raster layer names? If k is such a character
>>> vector,
>>>  you could try readRAST6(k). The second argument is a logical
>>> vector, not
>>>  vname= as you seem to think - that is in writeRAST6().
>>>  Hope this helps,
>>>  Roger
>>>  obiect <-readRAST6(k)
>> well maybe presented problem not enough clear
>> First - there is en mistake in code i typed
>> shuoud be:
>> for (i in k) {
>> here_I_need_obect_with_unique_name=readRAST6(i)
>> but in that way I recive obiect which every iteration will be
>> overwritten by nex raster map. At the end I will have obiect with
>> last raster map in string vector
>> How to preserve obiect created in the loop and control its name?
>> I think about something like this (for example) in the loop ??
> What I suggested was putting all the rasters into the same object -
> their names become the column names of the object. Since the current
> region is respected, they will be conformal. If you want multiple
> objects, use assign() which takes a character string as the name if
> the object being assigned to, but watch the scoping if you are doing
> this in a function.
> Roger
>> ob_a=readRAST6("a")
>> ob_b=readRAST6("b")
>> ob_c=readRAST6("c")
>> ob_z=readRAST6("z")
>> if I use this
>> there will be the problem with converting every layer (I mean:
>> "obiect at data$raster_name" i SpGridDataFrame) in multilayer
>> SpGridDataFrame to "im" class obiect
>> In general it is the problem how to control names of obiect if in the
>> loop we need to create more than one obiect
>> Hope I presented it clear
>> greetings
>> Jarek
that is solution!!
many thanks Roger!
Jarek
More information about the grass-stats mailing list
