[STATSGRASS] graphics in R
Jarosław Jasiewicz jarekj at amu.edu.pl
Fri Oct 5 06:26:21 EDT 2007
Matteo Dall'Amico napisał(a):
> Hello,
> I would like to raise a question about plotting: I would like to plot
> on the SAME graph the temperature with time of sensors at different depth.
> That means, I would like to have in the same graph on the x-axis the
> time, y-axis the temperature, and on the graph several curves with
> different colors representing the different depth.
> I have a file with the first column representing the time, column 2
> representing the temperature at depth1, column 3 the temperature at
> depth2... and so on.
> Does someone know how I could do that?
> Thanks a lot in advance,
> Matteo
> Matteo Dall'Amico
> PhD candidate
> CUDAM and department of Civil and Environmental Engineering
> Universita' degli Studi di Trento
> Via Mesiano 77 - 38050 Trento - Italy
> email: matteo.dallamico at ing.unitn.it
> <mailto:matteo.dallamico at ing.unitn.it>
> Tel. +39 0461 882610
> Fax +39 0461 882672
> http://www.dottorato.it/trento/
>_______________________________________________
>statsgrass mailing list
>statsgrass at grass.itc.it
>http://grass.itc.it/mailman/listinfo/statsgrass
plot(first_graph, col=red, xlim=c(min_time_of_whole_data,
max_time_of_whole_data), ylim=c(min_temp_of_whole_data,
max_temp_of_whole_data),....)
plot(second_graph, col="green", add=TRUE)
plot(n_graph, col="anyone", add=TRUE)
hope you need this
Jarek
More information about the grass-stats mailing list
