[STATSGRASS] sp_0.9-16 source on CRAN
Rainer M Krug Rainer+grass at krugs.de
Tue Oct 16 06:49:30 EDT 2007
Roger Bivand wrote:
> On Tue, 16 Oct 2007, Rainer M Krug wrote:
>> Hi Roger
>> first of all thanks a lot for your prompt reply. I tried it with two
>> other raster layers, and one worked.
>> I played around, and the problem seems top be the length of the output
>> variable:
SNIP
>> So it is a problem in grass itself.
>> I should be able to find a way around, but I should file a bug report.
> Yes, I should have remembered that something like it did come up before.
> I can see email traffic from July this year, thread here:
> http://grass.itc.it/pipermail/statsgrass/2007-July/000619.html
> So it is fixed in CVS for 6.3 and in CVS for 6.2.3.
Thanks a lot for all your help - I'll work around the problem .
And it is really MUCH faster now.
Rainer
> Roger
>> Thanks a million,
>> Rainer
>> Roger Bivand wrote:
>>>  On Tue, 16 Oct 2007, Rainer M. Krug wrote:
>>> >  Hi
>>> > >  I just upgraded to the new version, and I get an error message
>>> when >  importing an existing raster. The output is below.
>>>  This is not related to the sp update. Please do debug(readRAST6) and
>>>  re-run, stepping through until you pass the the setting of the command
>>>  string for r.out.bin. Please then print the cmd variable to screen and
>> debug: tull <- ifelse(.Platform$OS.type == "windows", system(cmd),
>> system(cmd,
>>    ignore.stderr = ignore.stderr))
>> Browse[1]> cmd
>> [1] "r.out.bin -b input=Hakea_seeds_2007
>> output=/home/rkrug/Documents/Projects/AlienSpread/R/../grass/simulation/.tmp/rkrug-linux/Hakea_seeds_2007
>> null=-1"
>> Browse[1]>
>>>  copy&paste it. It should have a -b flag. Please also give the output of
>>>  sessionInfo() for your system, and the output of system("g.version")
>>> too.
>>>  sessionInfo()
>> R version 2.6.0 (2007-10-03)
>> i686-pc-linux-gnu
>> locale:
>> LC_CTYPE=en_GB.UTF-8;LC_NUMERIC=C;LC_TIME=en_GB.UTF-8;LC_COLLATE=en_GB.UTF-8;LC_MONETARY=en_GB.UTF-8;LC_MESSAGES=en_GB.UTF-8;LC_PAPER=en_GB.UTF-8;LC_NAME=C;LC_ADDRESS=C;LC_TELEPHONE=C;LC_MEASUREMENT=en_GB.UTF-8;LC_IDENTIFICATION=C
>> attached base packages:
>> [1] stats     graphics  grDevices utils     datasets  methods   base
>> other attached packages:
>> [1] gstat_0.9-40    spgrass6_0.4-3  maptools_0.6-17 rgdal_0.5-15
>> [5] sp_0.9-16       foreign_0.8-23
>> loaded via a namespace (and not attached):
>> [1] grid_2.6.0     lattice_0.16-5
>>>  system("g.version")
>> GRASS 6.2.2 (2007)
>>>  The *.wld file got put in the correct place, so the *.hdr ought to have
>>>  been there too.
>>>  If you do debug(readBinGrid), you'll see where it fails now, about 4
>>> lines
>>>  in. You could also do list.files(dirname(fname)) just before it
>>> fails in
>>>  readBinGrid(), to check whether there ia anything else odd going on.
>>> Have
>>>  you checked to see whether it has been written anywhere else?
>>>  Roger
>>> > > > >   readRAST6("Hakea_seeds_2007")
>>> >  Creating BIL support files ...
>>> >  Header File = ld
>>> >  World File = >
>>> /home/rkrug/Documents/Projects/AlienSpread/R/../grass/simulation/.tmp/rkrug-linux/Hakea_seeds_2007.wld
>>> > >  Exporting Raster as double values(bytes=8)
>>> >  Using the Current Region settings ...
>>> >  north=6247000.000000
>>> >  south=6195000.000000
>>> >  east=270200.000000
>>> >  west=251000.000000
>>> >  r=520
>>> >  c=192
>>> > >  Percent complete:
>>> >  r.out.bin complete.
>>> >  Error in readBinGrid(rtmpfl11, colname = vname[i], proj4string =
>>> p4, >  integer = to_int) :
>>> >  no such file: >
>>> /home/rkrug/Documents/Projects/AlienSpread/R/../grass/simulation/.tmp/rkrug-linux/Hakea_seeds_2007.hdr
>>> > > > > >  The contents of the folder are as follow:
>>> (grass):~/Documents/Projects/AlienSpread/grass/simulation/.tmp/rkrug-linux
>>> > > >   ll Hakea*
>>> >  -rw-r--r-- 1 rkrug users 798720 2007-10-16 11:10 Hakea_seeds_2007
>>> >  -rw-r--r-- 1 rkrug users     60 2007-10-16 11:10 Hakea_seeds_2007.wld
>>> >  -rw-r--r-- 1 rkrug users 798720 2007-10-16 10:52 >
>>> Hakea_seedsDispersed_2007
>>> >  -rw-r--r-- 1 rkrug users     60 2007-10-16 10:52 >
>>> Hakea_seedsDispersed_2007.wld
>>> >  [Raster MASK present]
>>> >  GRASS 6.2.2 >
>>> > > > > >  Is there something wrong in my paths or os there a bug?
>>> > >  Thanks a lot,
>>> > > >  Rainer
>>> > > >  Roger Bivand wrote:
>>> > >  A new version of the foundation sp package is reaching CRAN
>>> mirrors, > >  and
>>> > >   Windows and OSX binaries should follow within a day or so.
>>> There is a
>>> > >   significant change in how SpatialGrid objects are created,
>>> which we > >  hope
>>> > >   will not affect users negatively, and which is giving a two
>>> orders of
>>> > >   magnitude speedup for reading larger rasters (single band 900
>>> by > >  3600 down
>>> > >   from 12 minutes to 6 seconds on an older 1.5GHz machine).
>>> > > > >   If anyone sees any negative impacts, please contact the
>>> authors
>>> > >   immediately directly.
>>> > > > >   Roger
More information about the grass-stats mailing list
