[GRASS-stats] problem with specific type of polygon
Roger Bivand Roger.Bivand at nhh.no
Thu Apr 9 16:02:11 EDT 2009
On Thu, 9 Apr 2009, Jarek Jasiewicz wrote:
> Hi
> it is difficult to reproduce on spearfish, because there are no data like
> this
> I vextorised watershed file and at the end of some watershed I have
> sutructure like on picture below (rather tipical for watershed):
>                          +  |                 __________|_
>                               |_|_
>                                  |_|_
>                                     |_|_
>                                        |_|
> Addationaly every square on right-down "stream" has his own centeroid but
> with the same cateogry like main centeroid
> I import these data to R with readVECT6 and I have more object than shoud be,
> because every square became a separtate vector with his own attributes (some
> of atrributes are multipied).
> In grass I can treat such group as one object by its category number but in
> R? How to force R to treat these group of polygons as one obiect
Jarek:
An attempt is made in the code with the remove.duplicates= argument. In
addition for polygons, you can try unionSpatialPolygons() in maptools to
force the objects belonging together into the same Polygons object.
Hope this helps,
Roger
> Jarek
> grass-stats mailing list
> grass-stats at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-stats
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats mailing list
