[GRASS-stats] Incompatible library version for module SOLVED but new problem with plugin=TRUE has emerged
Jarek Jasiewicz jarekj at amu.edu.pl
Fri Jan 2 13:38:54 EST 2009
Markus Neteler pisze:
> 2009/1/2 Jarek Jasiewicz <jarekj at amu.edu.pl>:
>> In fact I didn't use R for two month so maybe I lost something but  after
>>  compilation of grass 6.4 svn I tiried to read raster I recive the
>> following:
> I assume that you did not run
>  make distclean
> to compile GRASS (see below).
Thanks for ansver but unfortunately I always do makedistclean in grass
before compilation
addationaly I simply did:
 gdalinfo /home/jarekj/grassdata/Polska/PERMANENT/cellhd/Polska
ERROR:Incompatible library version for module
Here is the problem
so not the GRASS but grass-gdal plugin must to be recompiled. I think it
is not intended because plugin was created for to not compile gdal
everytime grass has ben recompiled
I ecompiled plugin, it and everthing is OK
But the issue with plugin which emerged is as follows:
r=readRAST6("Polska", plugin=FALSE)
Exporting raster as integer values (bytes=2)
Using the current region settings...
north=804414.520000
south=137864.430000
east=865559.620000
west=180375.670000
r=1333
c=1370
 100%
It is OK, my region settings are included
ra=readRAST6("Polska", plugin=TRUE)
/home/data/grassdata/Polska/PERMANENT/cellhd/Polska has GDAL driver GRASS
and has 21601 rows and 18001 columns
it is also OK because original map is rather big
next were eror due to file size
but this means that plugin ignores current region setings!
Jarek
_
_
More information about the grass-stats mailing list
