[GRASS-stats] Incompatible library version for module SOLVED but new problem with plugin=TRUE has emerged
Markus Neteler neteler at osgeo.org
Sat Jan 3 04:01:00 EST 2009
On Sat, Jan 3, 2009 at 7:54 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Fri, Jan 2, 2009 at 7:38 PM, Jarek Jasiewicz <jarekj at amu.edu.pl> wrote:
>> but this means that plugin ignores current region setings!
> Yes. That's why I suggested to implement r.out.gdal usage
> in the GRASS-R extension time ago (see this list archive,
> date    Sun, Jun 1, 2008 at 9:40 PM
> subject Re: [GRASS-stats] Speedup of readVECT6() with plugin
> There is a "plugin" switch which you set to plugin=TRUE, perhaps
> it needs to be FALSE to make use of the better + faster r.out.gdal
> which would solve your problem as it is resolution/region sensitive.
OK, I checked the source code of spgrass6_0.5-16.tar.gz
and the manual at
 http://cran.r-project.org/web/packages/spgrass6/index.html
which says:
"useGDAL:
   default FALSE using r.out.bin or r.in.bin, if TRUE use r.out.gdal
or r.in.gdal,
   GTiff, and readGDAL or writeGDAL
So this switch should solve your problem.
Markus
PS: Upon a test if GRASS is >= 6.4 I suggest to set useGDAL=TRUE
 in spgrass6.
More information about the grass-stats mailing list
