[GRASS-stats] Loading a point-vector table with 466 columns
Hamish hamish_b at yahoo.com
Fri May 22 13:31:16 EDT 2009
> Roger:
> Speed is a secondary issue - primary is just having things work,
> and handling the myriad variants of GRASS on different platforms
> is hard enough.
very true, and shapefile+DBF is probably (after the native vector format)
the second best tested. But at the same time shapefiles/DBF is a somewhat
lossy format and so no panacea.
regards,
Hamish
More information about the grass-stats mailing list
