[GRASS-stats] Loading a point-vector table with 466 columns
Hamish hamish_b at yahoo.com
Sun May 24 01:36:16 EDT 2009
Roger wrote:
> Three minutes instead of thirty+ suggests that the OGR
> plugin has trouble with SQLite as the DB format. So maybe
> the default for plugin= should be FALSE, not NULL and automatic
> use if present?
better: if cause for slowdown is isolated (or at least
reproducable) please file a bug report to get the plugin fixed.
That way e.g. qgis and others who use the plugin also get the
speedup.
> The plugin also creates a fictitious third dimension in
> (point at least) data that has created havoc, and has led
> to readVECT6() getting a pointDropZ= argument - that's why it
> says that wkbPoint is 3 with the plugin and (correctly) 2
> otherwise.
ditto.
Hamish
More information about the grass-stats mailing list
