[GRASS-stats] Loading a point-vector table with 466 columns
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Fri May 22 17:08:21 EDT 2009
Nikos:
> > I am trying to load a BIG table (=466 columns, 875 rows) of a grass
> > point-vector map in R. It takes too long to respond (as expected of
> > course)...
OK, I let it run and it worked. BUT, I forgot to use some kind of time
measuring (I read somewhere that it's pretty easy to do so in R).
I only know that it took more than 30 mins which, comparing to some
seconds of reading the .csv file is far away from "working ok". I can
let it run again if I find that time-measuring function again.
Cheers, Nikos
# the command and the response (just for the records)
# running R from within a GRASS location
# loading "spgrass6"
library(spgrass6) ; G <- gmeta6()
# read the attribute table
sample_2 <- readVECT6("sample_2_grid_points")
OGR data source with driver: GRASS
Source:
"/geo/grassdb/peloponnese/evaluation_utm/nik/vector/sample_2_grid_points/head", layer: "1"
with  875  rows and  466  columns
Feature type: wkbPoint with 3 dimensions
More information about the grass-stats mailing list
