[GRASS-stats] problem installing spgrass6 in R
Tim Holland timothyholland at gmail.com
Mon Oct 5 00:22:18 EDT 2009
Roger Bivand wrote:
> Install rgdal first:
> install.packages("rgdal", type="source",
> configure.args=c(--with-gdal-config="<where gdal-config is>",
> --with-proj-include="<where the proj headers are>",
> --with-proj-lib=<where the proj libs are>"))
> or something like that. Didn't it seem sensible to install the rgdal OSX
> binaries from kyngchaos?
> Once rgdal is installed, just install spgrass6 as a source package, no
> dependencies, please, and no configure arguments. These are two separate
> packages, where rgdal is what spgrass6 uses to do some of its work.
 Thanks again for the help.  It installed successfully! After your comment
about the rgdal binaries from kyngchaos, I installed them independently (I
guess until then I thought that using the 'dependencies' argument for
install packages would work for rgdal automatically), and it now works.
Sorry if that should have been obvious.
Best,
Tim
View this message in context: http://n2.nabble.com/problem-installing-spgrass6-in-R-tp3729191p3766876.html
Sent from the Grass - Stats mailing list archive at Nabble.com.
More information about the grass-stats mailing list
