[GRASS-stats] "g.region: command not found" using readRAST6 command
Daniel McInerney daniel.mcinerney at ucd.ie
Wed Oct 7 04:52:39 EDT 2009
Hi Tim,
Is R running within a GRASS session?
Regards,
Daniel.
Tim Holland wrote:
> Hello,
> I'm sorry to keep making so much noise on the list for what I'm sure are
> basic questions.
> I am having trouble loading in a GRASS raster into R using the readRAST6
> command.
> Using:
>> readRAST6("rasterMap",mapset="/Users/etc/my_mapset")
> I get the following error:
>> Error in if (file.exists(file) == FALSE) if (!missing(asText) && asText ==
>   argument is of length zero
>> Error in parseGRASS(cmd) : g.region not parsed
>> sh: g.region: command not found
> Is there something I am doing wrong here?
> Also, when I am working with spgrass6 in general, should I have my working
> directory set to the GRASS DBase I am using, or does that matter?
> Thank you for the help,
> Tim
>> sessionInfo()
> R version 2.9.2 (2009-08-24)
> i386-apple-darwin8.11.1
> locale:
> en_US.UTF-8/en_US.UTF-8/C/C/en_US.UTF-8/en_US.UTF-8
> attached base packages:
> [1] stats     graphics  grDevices utils     datasets  methods   base
> other attached packages:
> [1] spgrass6_0.6-9 XML_2.6-0      rgdal_0.6-12   sp_0.9-44
> loaded via a namespace (and not attached):
> [1] grid_2.9.2      lattice_0.17-25
More information about the grass-stats mailing list
