[GRASS-stats] "g.region: command not found" using readRAST6 command
    Tim Holland
    timothyholland at gmail.com
    Wed Oct  7 04:11:57 EDT 2009
Hello,
I'm sorry to keep making so much noise on the list for what I'm sure are
basic questions.
I am having trouble loading in a GRASS raster into R using the readRAST6
command.
Using:
>readRAST6("rasterMap",mapset="/Users/etc/my_mapset")
I get the following error:
>Error in if (file.exists(file) == FALSE) if (!missing(asText) && asText ==
  argument is of length zero
>Error in parseGRASS(cmd) : g.region not parsed
>sh: g.region: command not found
Is there something I am doing wrong here?
Also, when I am working with spgrass6 in general, should I have my working
directory set to the GRASS DBase I am using, or does that matter?
Thank you for the help,
Tim
> sessionInfo()
R version 2.9.2 (2009-08-24)
i386-apple-darwin8.11.1
locale:
en_US.UTF-8/en_US.UTF-8/C/C/en_US.UTF-8/en_US.UTF-8
attached base packages:
[1] stats     graphics  grDevices utils     datasets  methods   base
other attached packages:
[1] spgrass6_0.6-9 XML_2.6-0      rgdal_0.6-12   sp_0.9-44
loaded via a namespace (and not attached):
[1] grid_2.9.2      lattice_0.17-25
View this message in context: http://n2.nabble.com/g-region-command-not-found-using-readRAST6-command-tp3780384p3780384.html
Sent from the Grass - Stats mailing list archive at Nabble.com.
More information about the grass-stats
