[GRASS-stats] Example code for MRPP on a multivariate data set
Nikos Alexandris nik at nikosalexandris.net
Sun Jan 9 07:46:39 EST 2011
Nikos A:
> > To have some results for my work, I also run the procedures on smaller
> > subsets (say 3000 observations instead of 18865) which takes some time
> > but is feasible @home.
Some timings:
I've completed the procedures on smaller subsets (in total 10). The subsets
(data.frames) contain 3000 random observations with 6 variables and 1 factor
of 7 levels.
  - Each data.frame took about 41 minutes on quad-core at 3GHz/8GB-RAM.
  - Also, data.frames with 1040 observations, 6 variables, 1 factor with 5
levels took about 10 minutes each on core-duo at 2.53GHz/6GB-RAM.
> > Currently there is a process running on a big cluster (thanks to a very
> > kind person who's always there). Hopefully we'll know soon enough how
> > much time this will take.
Markus N:
> The job is still running on "my" blade :) Using 68GB of RAM.
> Does anyone in the list have experience in running R on a multicore
> system? This list is rather overwhelming for me:
>  http://cran.r-project.org/web/views/HighPerformanceComputing.html
> An openMP approach or likewise with implicit parallelism would be great
> since I cannot rewrite R...
I would certainly try to work on this if pointed to the right direction (no
previous experience on this though) although my time is running away...
Thanks for all, Nikos
More information about the grass-stats mailing list
