[GRASS-stats] Spgrass6 syscmd error
Levent Burggraef levent.burggraef at gwdg.de
Wed Sep 21 10:22:03 EDT 2011
Hi list,
i posted this message in the GRASS user mailing list first and was asked
to post again here.
I'm running GRASS 6.4.0 and R 2.9.1 with the package Spgrass6.
I work on SUSE Linux Enterprise Server 10.
I also tried the same packages (with GRASS version 6.4.0+42329 (2010) ) and
commands on my Ubuntu 10.10. laptop and got exactly the same error message.
After starting an R session in GRASS, loading Spgrass6 and running a
command, i get an error somehow related to the R command “syscmd”,
reporting unused arguments.
The example below relates to gmeta6(), but it happens with any command from
Spgrass6.
> library(spgrass6)
Lade nötiges Paket: sp
Lade nötiges Paket: rgdal
Geospatial Data Abstraction Library extensions to R successfully loaded
Loaded GDAL runtime: GDAL 1.6.3, released 2009/11/19
Path to GDAL shared files: /usr/share/gdal
Loaded PROJ.4 runtime: Rel. 4.7.1, 23 September 2009
Path to PROJ.4 shared files: (autodetected)
Lade nötiges Paket: XML
GRASS GIS interface loaded with GRASS version: GRASS 6.4.0svn (2009)
and location: projekt_sued
> gmeta6()
Fehler in system(syscmd, intern = intern, ignore.stderr =
ignore.stderr,  :
  unbenutzte(s) Argument(e) (ignore.stdout = Sys_ignore.stdout)
Thanks for your help,
Levent
Levent Burggraef
Buesgen Institute
Dept. for Forest Zoology and Forest Conservation
Buesgenweg 3
37077 Goettingen
More information about the grass-stats mailing list
