[GRASS-stats] Spgrass6 syscmd error
Rainer M Krug r.m.krug at gmail.com
Wed Sep 21 10:28:36 EDT 2011
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 21/09/11 16:22, Levent Burggraef wrote:
> Hi list,
Hi
Your version of R is very old, and I guess that is the problem. The
actual version of R is 2.13.1 and the actual version of spgrass6 is 0.7-4.
Could you please update (or ask you system admin) to update, as I
guess that the problem is an incompatiility between spgrass6 and R.
Please compare: the command system() takes in the actuial version the
following parameter, and I assume that it did not include
ignore.stdout in your version - so updating is the only version.
 system(command, intern = FALSE,
            ignore.stdout = FALSE, ignore.stderr = FALSE,
            wait = TRUE, input = NULL, show.output.on.console = TRUE,
            minimized = FALSE, invisible = TRUE)
Cheers,
Rainer
> i posted this message in the GRASS user mailing list first and was
> asked to post again here. I'm running GRASS 6.4.0 and R 2.9.1 with
> the package Spgrass6. I work on SUSE Linux Enterprise Server 10.
> I also tried the same packages (with GRASS version 6.4.0+42329
> (2010) ) and commands on my Ubuntu 10.10. laptop and got exactly
> the same error message.
> After starting an R session in GRASS, loading Spgrass6 and running
> a command, i get an error somehow related to the R command
> “syscmd”, reporting unused arguments. The example below relates to
> gmeta6(), but it happens with any command from Spgrass6.
>> library(spgrass6)
> Lade nötiges Paket: sp Lade nötiges Paket: rgdal Geospatial Data
> Abstraction Library extensions to R successfully loaded Loaded GDAL
> runtime: GDAL 1.6.3, released 2009/11/19 Path to GDAL shared files:
> /usr/share/gdal Loaded PROJ.4 runtime: Rel. 4.7.1, 23 September
> 2009 Path to PROJ.4 shared files: (autodetected) Lade nötiges
> Paket: XML GRASS GIS interface loaded with GRASS version: GRASS
> 6.4.0svn (2009) and location: projekt_sued
>> gmeta6()
> Fehler in system(syscmd, intern = intern, ignore.stderr =
> ignore.stderr,  : unbenutzte(s) Argument(e) (ignore.stdout =
> Sys_ignore.stdout) --------------
> Thanks for your help, Levent
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel :       +33 - (0)9 53 10 27 44
Cell:       +33 - (0)6 85 62 59 98
Fax :       +33 - (0)9 58 10 27 44
Fax (D):    +49 - (0)3 21 21 25 22 44
email:      Rainer at krugs.de
Skype:      RMkrug
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAk559JQACgkQoYgNqgF2egp3NgCfVmp3CPLzRHbc2pAHddMxoJBt
4s4AnRMJl7yL6YkdDOQrKP5F37X0rOW1
=VWiX
-----END PGP SIGNATURE-----
More information about the grass-stats mailing list
