[GRASS-stats] Spgrass6 syscmd error
Levent Burggraef levent.burggraef at gwdg.de
Sat Sep 24 02:26:50 EDT 2011
Thanks Rainer,
i also thought that my problems occured as a result of our server being
out of date, but as i got the same error with R 2.11 on my laptop i
didn't really believe it. I upgraded to R 2.13.1 now and everything
works just fine.
Bye,
Levent
Am 21.09.2011 16:28, schrieb Rainer M Krug:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> On 21/09/11 16:22, Levent Burggraef wrote:
>> Hi list,
> Hi
> Your version of R is very old, and I guess that is the problem. The
> actual version of R is 2.13.1 and the actual version of spgrass6 is 0.7-4.
> Could you please update (or ask you system admin) to update, as I
> guess that the problem is an incompatiility between spgrass6 and R.
> Please compare: the command system() takes in the actuial version the
> following parameter, and I assume that it did not include
> ignore.stdout in your version - so updating is the only version.
>   system(command, intern = FALSE,
>              ignore.stdout = FALSE, ignore.stderr = FALSE,
>              wait = TRUE, input = NULL, show.output.on.console = TRUE,
>              minimized = FALSE, invisible = TRUE)
> Cheers,
> Rainer
>> i posted this message in the GRASS user mailing list first and was
>> asked to post again here. I'm running GRASS 6.4.0 and R 2.9.1 with
>> the package Spgrass6. I work on SUSE Linux Enterprise Server 10.
>> I also tried the same packages (with GRASS version 6.4.0+42329
>> (2010) ) and commands on my Ubuntu 10.10. laptop and got exactly
>> the same error message.
>> After starting an R session in GRASS, loading Spgrass6 and running
>> a command, i get an error somehow related to the R command
>> “syscmd”, reporting unused arguments. The example below relates to
>> gmeta6(), but it happens with any command from Spgrass6.
>>> library(spgrass6)
>> Lade nötiges Paket: sp Lade nötiges Paket: rgdal Geospatial Data
>> Abstraction Library extensions to R successfully loaded Loaded GDAL
>> runtime: GDAL 1.6.3, released 2009/11/19 Path to GDAL shared files:
>> /usr/share/gdal Loaded PROJ.4 runtime: Rel. 4.7.1, 23 September
>> 2009 Path to PROJ.4 shared files: (autodetected) Lade nötiges
>> Paket: XML GRASS GIS interface loaded with GRASS version: GRASS
>> 6.4.0svn (2009) and location: projekt_sued
>>> gmeta6()
>> Fehler in system(syscmd, intern = intern, ignore.stderr =
>> ignore.stderr,  : unbenutzte(s) Argument(e) (ignore.stdout =
>> Sys_ignore.stdout) --------------
>> Thanks for your help, Levent
> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
> Biology, UCT), Dipl. Phys. (Germany)
> Centre of Excellence for Invasion Biology
> Stellenbosch University
> South Africa
> Tel :       +33 - (0)9 53 10 27 44
> Cell:       +33 - (0)6 85 62 59 98
> Fax :       +33 - (0)9 58 10 27 44
> Fax (D):    +49 - (0)3 21 21 25 22 44
> email:      Rainer at krugs.de
> Skype:      RMkrug
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.11 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
> iEYEARECAAYFAk559JQACgkQoYgNqgF2egp3NgCfVmp3CPLzRHbc2pAHddMxoJBt
> 4s4AnRMJl7yL6YkdDOQrKP5F37X0rOW1
> =VWiX
> -----END PGP SIGNATURE-----
More information about the grass-stats mailing list
