[GRASS-stats] Spgrass6 syscmd error
Rainer M Krug r.m.krug at gmail.com
Sat Sep 24 03:57:37 EDT 2011
On Sat, Sep 24, 2011 at 8:26 AM, Levent Burggraef
<levent.burggraef at gwdg.de>wrote:
> Thanks Rainer,
> i also thought that my problems occured as a result of our server being out
> of date, but as i got the same error with R 2.11 on my laptop i didn't
> really believe it. I upgraded to R 2.13.1 now and everything works just
> fine.
Great to hear that.
Cheers,
Rainer
> Bye,
> Levent
> Am 21.09.2011 16:28, schrieb Rainer M Krug:
>  -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> On 21/09/11 16:22, Levent Burggraef wrote:
>>> Hi list,
>> Hi
>> Your version of R is very old, and I guess that is the problem. The
>> actual version of R is 2.13.1 and the actual version of spgrass6 is 0.7-4.
>> Could you please update (or ask you system admin) to update, as I
>> guess that the problem is an incompatiility between spgrass6 and R.
>> Please compare: the command system() takes in the actuial version the
>> following parameter, and I assume that it did not include
>> ignore.stdout in your version - so updating is the only version.
>>  system(command, intern = FALSE,
>>             ignore.stdout = FALSE, ignore.stderr = FALSE,
>>             wait = TRUE, input = NULL, show.output.on.console = TRUE,
>>             minimized = FALSE, invisible = TRUE)
>> Cheers,
>> Rainer
>>  i posted this message in the GRASS user mailing list first and was
>>> asked to post again here. I'm running GRASS 6.4.0 and R 2.9.1 with
>>> the package Spgrass6. I work on SUSE Linux Enterprise Server 10.
>>> I also tried the same packages (with GRASS version 6.4.0+42329
>>> (2010) ) and commands on my Ubuntu 10.10. laptop and got exactly
>>> the same error message.
>>> After starting an R session in GRASS, loading Spgrass6 and running
>>> a command, i get an error somehow related to the R command
>>> “syscmd”, reporting unused arguments. The example below relates to
>>> gmeta6(), but it happens with any command from Spgrass6.
>>>> library(spgrass6)
>>> Lade nötiges Paket: sp Lade nötiges Paket: rgdal Geospatial Data
>>> Abstraction Library extensions to R successfully loaded Loaded GDAL
>>> runtime: GDAL 1.6.3, released 2009/11/19 Path to GDAL shared files:
>>> /usr/share/gdal Loaded PROJ.4 runtime: Rel. 4.7.1, 23 September
>>> 2009 Path to PROJ.4 shared files: (autodetected) Lade nötiges
>>> Paket: XML GRASS GIS interface loaded with GRASS version: GRASS
>>> 6.4.0svn (2009) and location: projekt_sued
>>>  gmeta6()
>>> Fehler in system(syscmd, intern = intern, ignore.stderr =
>>> ignore.stderr,  : unbenutzte(s) Argument(e) (ignore.stdout =
>>> Sys_ignore.stdout) --------------
>>> Thanks for your help, Levent
>> - -- Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
>> Biology, UCT), Dipl. Phys. (Germany)
>> Centre of Excellence for Invasion Biology
>> Stellenbosch University
>> South Africa
>> Tel :       +33 - (0)9 53 10 27 44
>> Cell:       +33 - (0)6 85 62 59 98
>> Fax :       +33 - (0)9 58 10 27 44
>> Fax (D):    +49 - (0)3 21 21 25 22 44
>> email:      Rainer at krugs.de
>> Skype:      RMkrug
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v1.4.11 (GNU/Linux)
>> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
>> iEYEARECAAYFAk559JQACgkQoYgNqg**F2egp3NgCfVmp3CPLzRHbc2pAHddMx**oJBt
>> 4s4AnRMJl7yL6YkdDOQrKP5F37X0rO**W1
>> =VWiX
>> -----END PGP SIGNATURE-----
> ______________________________**_________________
> grass-stats mailing list
> grass-stats at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/grass-stats<http://lists.osgeo.org/mailman/listinfo/grass-stats>
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology,
South Africa
Fax (F):       +33 - (0)9 58 10 27 44
Skype:      RMkrug
URL: http://lists.osgeo.org/pipermail/grass-stats/attachments/20110924/b0586706/attachment.html
More information about the grass-stats mailing list
