[GRASS-stats] Nearest neighbour distance distribution but between polygons
G. Allegri giohappy at gmail.com
Mon May 7 08:35:06 EDT 2012
In Grass maybe you could use the boundaries instead of the areas. The
distances would be between the boundaries' linestrings instead of centroids.
giovanni
2012/5/7 Roger Bivand <Roger.Bivand at nhh.no>
> On Mon, 7 May 2012, Rainer M Krug wrote:
>  -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> Hi
>> I have the following (presumibly simple?) question:
>> I have a certain number of patches (islands) in a landscape of which I
>> need to know the nearest neighbour distance. As the problem is related to
>> dispersal, I would need to know the actual shortest distance between the
>> actual polygons and not only the centroids. Is there an easy way to obtain
>> these in R or in GRASS? I am only aware of nearest neighbour distance
>> between points.
> In R, if the coordinates are projected, use gDistance(..., byid=TRUE) in
> the rgeos package to get a matrix in the metric of the projection. If not
> projected, project if possible.
> I don't think that the geosphere package provides for the unprojected case.
> Roger
>> Thanks,
>> Rainer
>> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
>> Biology, UCT), Dipl. Phys.
>> (Germany)
>> Centre of Excellence for Invasion Biology
>> Stellenbosch University
>> South Africa
>> Tel :       +33 - (0)9 53 10 27 44
>> Cell:       +33 - (0)6 85 62 59 98
>> Fax :       +33 - (0)9 58 10 27 44
>> Fax (D):    +49 - (0)3 21 21 25 22 44
>> email:      Rainer at krugs.de
>> Skype:      RMkrug
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v1.4.11 (GNU/Linux)
>> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
>> iEYEARECAAYFAk+**nux4ACgkQoYgNqgF2egqaDgCeKx1Bk**rDsn+NldthK1GzFVYWp
>> stwAnRz+uj47cBMNid/**QPdIRXwAnVs/8
>> =yBff
>> -----END PGP SIGNATURE-----
>> ______________________________**_________________
>> grass-stats mailing list
>> grass-stats at lists.osgeo.org
>> http://lists.osgeo.org/**mailman/listinfo/grass-stats<http://lists.osgeo.org/mailman/listinfo/grass-stats>
> Roger Bivand
> Department of Economics, NHH Norwegian School of Economics,
> Helleveien 30, N-5045 Bergen, Norway.
> voice: +47 55 95 93 55; fax +47 55 95 95 43
> e-mail: Roger.Bivand at nhh.no
URL: http://lists.osgeo.org/pipermail/grass-stats/attachments/20120507/1c60f4ef/attachment.html
More information about the grass-stats mailing list
