[GRASS-stats] Nearest neighbour distance distribution but between polygons
Rainer M Krug r.m.krug at gmail.com
Mon May 7 08:44:12 EDT 2012
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 07/05/12 14:35, G. Allegri wrote:
> In Grass maybe you could use the boundaries instead of the areas. The distances would be
> between the boundaries' linestrings instead of centroids.
Sounds definitely like an option to keep in mind - but what Roger suggested is easier to implement
right now.
Thanks,
Rainer
> giovanni
> 2012/5/7 Roger Bivand <Roger.Bivand at nhh.no <mailto:Roger.Bivand at nhh.no>>
> On Mon, 7 May 2012, Rainer M Krug wrote:
> Hi
> I have the following (presumibly simple?) question:
> I have a certain number of patches (islands) in a landscape of which I need to know the nearest
> neighbour distance. As the problem is related to dispersal, I would need to know the actual
> shortest distance between the actual polygons and not only the centroids. Is there an easy way
> to obtain these in R or in GRASS? I am only aware of nearest neighbour distance between
> points.
>> In R, if the coordinates are projected, use gDistance(..., byid=TRUE) in the rgeos package
>> to get a matrix in the metric of the projection. If not projected, project if possible.
>> I don't think that the geosphere package provides for the unprojected case.
>> Roger
> Thanks,
> Rainer
> _________________________________________________ grass-stats mailing list
> grass-stats at lists.osgeo.org <mailto:grass-stats at lists.osgeo.org>
> http://lists.osgeo.org/__mailman/listinfo/grass-stats
> <http://lists.osgeo.org/mailman/listinfo/grass-stats>
> -- Roger Bivand Department of Economics, NHH Norwegian School of Economics, Helleveien 30,
> N-5045 Bergen, Norway. voice: +47 55 95 93 55 <tel:%2B47%2055%2095%2093%2055>; fax +47 55 95 95
> 43 <tel:%2B47%2055%2095%2095%2043> e-mail: Roger.Bivand at nhh.no <mailto:Roger.Bivand at nhh.no>
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys.
(Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel :       +33 - (0)9 53 10 27 44
Cell:       +33 - (0)6 85 62 59 98
Fax :       +33 - (0)9 58 10 27 44
Fax (D):    +49 - (0)3 21 21 25 22 44
email:      Rainer at krugs.de
Skype:      RMkrug
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAk+nw5wACgkQoYgNqgF2egoxAgCfejlz4SMXuPYv/A2IwR/3VsRp
Q8QAn1xHWdibO+Re4wCeJSBptOpdzOM4
=kBdo
-----END PGP SIGNATURE-----
More information about the grass-stats mailing list
