[GRASS-stats] Nearest neighbour distance distribution but between polygons
Rainer M Krug r.m.krug at gmail.com
Mon May 7 08:42:48 EDT 2012
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 07/05/12 14:25, Roger Bivand wrote:
> On Mon, 7 May 2012, Rainer M Krug wrote:
> Hi
> I have the following (presumibly simple?) question:
> I have a certain number of patches (islands) in a landscape of which I need to know the
> nearest neighbour distance. As the problem is related to dispersal, I would need to know the
> actual shortest distance between the actual polygons and not only the centroids. Is there an
> easy way to obtain these in R or in GRASS? I am only aware of nearest neighbour distance
> between points.
Hi Roger
>> In R, if the coordinates are projected, use gDistance(..., byid=TRUE) in the rgeos package to
>> get a matrix in the metric of the projection. If not projected, project if possible.
Exactly what I was looking for - the geometries are projected, so absolutely no problem.
Thanks a lot,
Rainer
>> I don't think that the geosphere package provides for the unprojected case.
>> Roger
> Thanks,
> Rainer
>> _______________________________________________ grass-stats mailing list
>> grass-stats at lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/grass-stats
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys.
(Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel :       +33 - (0)9 53 10 27 44
Cell:       +33 - (0)6 85 62 59 98
Fax :       +33 - (0)9 58 10 27 44
Fax (D):    +49 - (0)3 21 21 25 22 44
email:      Rainer at krugs.de
Skype:      RMkrug
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAk+nw0gACgkQoYgNqgF2egrVLQCfXxjpJvxuPpMMoWVHtM/IrC/9
e8AAmQHoKaGZq2gJ4WI3HIELBPxLblpo
=DOUj
-----END PGP SIGNATURE-----
More information about the grass-stats mailing list
